removing lifts
Old Apr 17, 2018 | 12:35 PM
jarjack's Avatar
jarjack
Default removing lifts
what all would i need to remove the 6" lift off and return it to level height. I like the lift but it would be easier to tow stuff with less height. I have 2012 Ram 2500
Old Apr 17, 2018 | 12:56 PM
Tools. You would need tools. Jack stands (or a lift), impact wrenches would be a good idea. Penetrating fluid on the fasteners. Good lighting. Safety glasses, don't forget those. If you have oversized wheels/tires, you probably will need to go back to stock size there too.
Old Apr 17, 2018 | 01:07 PM
jarjack's Avatar
jarjack
I got the tools. can i just switch the lift kit out for a leveling kit?
Old Apr 17, 2018 | 01:09 PM
Yes. You would need all the stock hardware and fasteners that might have been removed to install the lift. Example, if you have a 6" block on the rear, you would need the original u-bolts once you remove the blocks.
