Vibrating 2005 ram 1500
Old May 10, 2018 | 12:47 AM
Mr.Dickens's Avatar
Mr.Dickens
Default Vibrating 2005 ram 1500
I have a 2005 dodge ram 1500. When accelerating at speeds of 45-65 there is a slight vibration which seems to be coming from the rear or center of the truck. The vibration stops when I let go of the gas or go slower then 45. I was thinking maybe ujoints but was unsure. I did have a bad pinion seal on the dif which I replaced already.
Old May 10, 2018 | 07:14 AM
bdhuntr's Avatar
bdhuntr
My guess is U-joints. Just replaced them (174K miles) and had the rear rebuilt as well. I had the same symptoms.
Old May 10, 2018 | 07:16 AM
jrsick's Avatar
jrsick
I second the u-joint. Only way to tell is to check them for play.
Old May 10, 2018 | 09:42 PM
Mr.Dickens's Avatar
Mr.Dickens
Ujoints where definitely the problem. Thanks!
