How to bypass fuel relay on 2007 Dodge Ram
Old May 13, 2018 | 10:58 AM
Raidergod's Avatar
Raidergod
Default How to bypass fuel relay on 2007 Dodge Ram
How to bypass fuel relay on a 2007 Dodge Ram with a 5.7
Old May 14, 2018 | 10:09 AM
HemiLonestar's Avatar
HemiLonestar
And why do you want to bypass it? What are you trying to do?
Old Nov 19, 2019 | 08:28 PM
davb673's Avatar
davb673
I have also started looking for this information, as I am going to install 12-hole injectors in my truck. But, it seems the geniuses at Dodge elected to solder the fuel pump relay into the TIPM fuse/relay box, and bury it inside so you cannot easily find it...much less replace it. Originally I was looking for the fuel pump fuse. But it seems it is inside the buried relay, as best I can tell. I plan to go on a scouting mission to find the fuel pump connector, and just unplug it so I can depressurize the fuel manifold.
[edit] looks like pin 4, the brown wire, on connector C1 for the TIPM, is the fuel pump wire. I cut it and could not start the truck. Added terminals so I can drive in the meantime, but this should let me relieve fuel rail pressure when I pull it to swap injectors.
*I realize this thread is a year old, but wanted to add this in the event someone else starts looking.
