Torque Converter problem
Hey, first post here
2006 ram 1500 2wd 5.7 Hemi w/ 165000
Yesterday I changed the rear most u-joint (connecting to rear diff), because it was squeaking. Squeak is gone but I noticed a weird problem today. My car would not decelerate when I let off the gas...as if cruise control was on. No weird noises or vibration. I marked the driveshaft and put it back the same. I did loose a tiny bit of trans fluid when I pulled the drive shaft, and didn’t top it off (it wasn’t even enough to fill the bottom of a small bucket). From what I’ve read so far I’m thinking maybe something with the torque converter? Any help is much appreciated
