‘07 indicator circuit shut down on PCM
Old Jun 29, 2018 | 09:38 AM
harby's Avatar
harby
Lightbulb ‘07 indicator circuit shut down on PCM
Hey,
It’s been along time since I posted on here, unfortunately I’m posting about some issues with electrics.......
Has anyone had issues with an indicator circuit shutting down on the PCM? My left indicator circuit operates the relay at high speed as it would if a bulb was blown and there is no output for the rear left indicator circuit from the PCM. The front left circuit does have output, but as mine is a U.K. spec truck it has a dummy relay on that circuit
As mine is a U.K. truck, it has been modified, so that all the indicators run on the rear circuit, I’ve checked for shorts and done a current draw check with power direct from the battery, which read the same for left and right, I even connected the right circuit to the left to see if it would liven up and it didn’t.
Is there a way to reset the PCM?
All help appreciated!
Paul
Old Jun 30, 2018 | 06:33 AM
harby's Avatar
harby
Temporarily I have connected the rear indicator to the trailer circuit and the front indicator to its original circuit, so I have a fast but working left indicator.
Old Sep 5, 2018 | 07:19 AM
harby's Avatar
harby
Has nobody else had this issue before?
