08 ram 1500
Old Sep 26, 2018 | 10:38 PM
Deztooz's Avatar
Deztooz
Default 08 ram 1500
Ive replaced both front upper control arm/ball joint, shocks, tie rods inner and outer. So here is my issue. When i hit a bump or anything not level, i feel and hear a knocking sound on passenger side front end. Ive checked stabilzer bar and bushings and all looks good. Any help with diagnosing this would be appreciated. Thanks in advance
Old Sep 27, 2018 | 07:35 AM
Was it doing this before you replaced parts? If not, suspect the work you did or the parts you used.
Old Sep 27, 2018 | 08:24 AM
Deztooz's Avatar
Deztooz
New parts and it was making noise prior. I replaced parts mentioned thinking it was the issue and still has knocking sound.
Old Sep 27, 2018 | 08:28 AM
ZEN357's Avatar
ZEN357
Something else is wrong. It's not the parts you used. Check for anything that has come loose.
