New Gears for my 6" lift?
Old Dec 8, 2005 | 04:35 AM
waterdogg22's Avatar
waterdogg22
Default New Gears for my 6" lift?
I have recently lifted my '03 1500 4x4 with a 6" Fabtech suspension lift with rear leaf springs from Skyjacker. I still have the stock 392 gears but feel I need to upgrade. I have noticed a lag when going through the mountains from Arizona to San Diego. I'm pretty green when it comes to gears and such I was just wondering if there was anyone with some good suggestions for the gears I should go with. I am running 35s on 17"s. The majority of my play area encompasses sand and minimal mud with the occasional rock. Any and all help is truly appreciated.
Thanks
Switz
Old Dec 8, 2005 | 12:02 PM
Phatboy's Avatar
Phatboy
Default RE: New Gears for my 6" lift?
There is a conversion tool, I believe at www.4wheelparts.com that should give you the right gear for the diffence in tire size. I am guessing it will be around a 4:56, because I dont think a 4:11 will be enough to get the RPMs back in range.
Old Dec 9, 2005 | 03:09 AM
waterdogg22
Thanks for the heads up. I'll check it out.
Old Dec 9, 2005 | 09:26 PM
HemiBuell's Avatar
HemiBuell
4.56 is a huge jump. I'm going to check out that conversion also. Planning on doing 35's soon myself.
Old Dec 9, 2005 | 11:48 PM
Saint's Avatar
Saint
You won't go wrong with 4.56s, even if it's too big of a jump it will give you a hell of a boost down low.
Old Dec 10, 2005 | 02:55 AM
osteodoc08's Avatar
osteodoc08
Don't forget that you've got to switch ratios front and back on a 4x4.
