Truck cranks does not fire
Old Dec 9, 2018 | 02:08 PM
fireman301's Avatar
fireman301
Default Truck cranks does not fire
2008 dodge ram 1500 turns over but does not start. Just cranks and will not fire.
Old Dec 9, 2018 | 05:03 PM
3rdgens4sell's Avatar
3rdgens4sell
If i could bet money on it odds would be in favor of crank sensor or cam sensor. Have you checked for fuel or spark? Did you try opening the throttle while cranking?
Old Dec 9, 2018 | 08:21 PM
jrsick's Avatar
jrsick
yep, crank or cam sensor. Crank sensor is most likely culprit so I recommend replacing that one first. Be careful not to break it when you're taking the old one out, some are stuck in there good.
