2004 Dodge 1500
Having a problem with my 2004 Dodge 1500 5.7 hemi going into limp mode, I have changed the throttle body and still going into this mode. Changed out the pedal positioning sensor also (from a junk yard) the lightning bolt comes on and then I will get a code of p0129, looking for help. Thanks
Possible causes for this code include:
Corroded connector face at the MAF/BPS sensor
Insufficient engine vacuum due to engine wear, an ignition misfire or clogged catalytic converter
Faulty BPS Open or shorted wiring for the MAP sensor and/or the BPS
Insufficient system ground at the MAF/BPS
Defective PCM or PCM programming error
