TCC Solenoid CEL with P0740/P0700 - What Next??
I quoted you to let you know it gets the temp from the tranny not the engine :b
Sincerely hope that that is the problem. Wondering if it would be best to pay an hour to the Dodge Stealer (ummmm.... I mean dealer) to have them diagnose which wire is the issue. I think that might be it as there have been a couple of other wires that possibly had some mice that had a little after midnight snack. The tell tale sign?? Mice poop in on the top of the engine!
Would it be a fairly easy thing for me to troubleshoot?? Is the wire relatively straightforward?? I am researching right now where the stinkin' wire is located on the 545rfe. I'll find it! Ha Ha!~
THANK YOU SO much for your help!
I was curious and did a tad of research. Appears the trans temp sensor is inside trans. Requires removal of valve body to get at it....I think I would start by checking external wiring first so you dont have to drain fluid yet again....fingers crossed lol
Go to a Mom and Pop shop that does transmissions. They usually have a scan tool (and cheaper then the dealer) and see if they can help. Now you can buy the internal transmission harness, but that won't help if you have a bad wire going to the transmission. Best thing so you aren't wasting money is too buy a multimeter and check every wire going to the transmission. Also check the connector on the transmission they sometimes get bent or corroded.
And @TrueDogman THANK YOU so much for the research and the temp sensor inside the transmission. This would be the 3rd time draining the transmission fluid. Kind of gets expensive so I like the idea of wires first. To both of you... would I just put one looooong wire on one side of the multimeter and use the other probe to check continuity?? Probably need to have two people to do this efficiently, right?? And, of course, one side of the harness is at the transmission...where is the other side?? Up in the engine compartment?? At the fuse box?? At the main ECM?? TCM?? Or just try to follow it visually??
Thank you guys for the help... I am very grateful!
@MoparFanatic21 I love the idea of a mom and pop shop as it really does help out small business and they would probably care a bit better. In trying to determine the wires that are bad, would you start with a visual check and if all seemed to be OK, then use my multimeter in Ohms/resistance setting and try to test every wire?? I kind of assume yes. Will check EVERYTHING!
I think I would keep it simple first and try to do a real good visual inspection. Identify the wires at the transmission (or at least some of them) and try to follow them back towards the PCM. Watch for certain areas in the loom that might be more prone to failure like closer to heat, corrosion areas or near top of engine where the mice decided to hang out. Might find some messed up wiring you can repair without using a multimeter ??
These are tough without a schematic
Then again maybe were barking up the wrong tree but its worth the effort in my opinion
Wanted to give you guys an update (I have been at the fire station A LOT and haven't had the time to look in depth until now). The wiring harnesses look pretty good and I have tried to trace the wiring as far as possible. It is really hard to follow it all the way. I went to a mom and pop shop and they are going to work to diagnose it by watching all the shift patterns and slippage when the torque converter locks up. Wasn't able to get the converter to lock on the 10 minute drive that he did and I am going to bring it back for a longer test on MLK holiday. The owner stated that the shift patterns look really good. I will totally keep you updated. I, like you guys, strongly think that it is a circuit issue and not a torque converter issue. I will let the diagnosing happen but if it is a "you need a new torque converter and should rebuild the tranny at the same time." I might work for a second opinion.
Those wiring harnesses are HUGE and tracing the wires looks to be a royal pain in the butt! Going to take another look tomorrow and see if I can see anything else missed yesterday.
Thanks again for your time!
Thats just it...The TCC isnt going to lock up no matter how much its driven because the electrical signal isnt being received properly by the shift solenoid.
Years ago when TCC first originated many people didnt like how they performed. I know people who installed a switch where the driver could control when the TCC would activate.
You dont happen to have any switches in the drivers area that dont seem to do anything ?
