Engine switch please help
Hello! I have a 2005 Ram 1500 with a 5.7 Ltr v8 but the engine is blown, I found a 2005 Ram 2500 with a 5.7 Ltr v8 motor, can I switch these without any problems, or just changing a few small things since same year? Any help would be really appreciated, thankyou! |
Are they both 5.7s? If so, should be a direct swap.
Yes, they are both 5.7 V8 hemis, i was just confused about the 1500 and 2500 wasn’t sure if they would match
Thankyou so much! |
Originally Posted by Jarret Sullivan
(Post 3425655)
Really appreciate it man! |
The 2500s don't have MDS, so you will have to pull the plugs and put in the selenoids.
(Post 3425724)
Actually aren't the MDS selenoids located under the intake manifold?
Originally Posted by ZEN357
(Post 3425733)
Now, if the truck the engine is going into actually HAS MDS, and expects things to change when it tries to engage it, (it will still cut fuel to those cylinders) THAT will be a problem. The engine block should be the same though, but, I think cam, and lifters are different as well, so, it isn't just a matter of adding the solenoids. Easier approach might be to disable MDS in the programming. |
