Need help finding a part
Old Feb 5, 2019 | 03:15 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You can't convert switches from momentary to toggle. it's *possible*, but, only if you have the manufacturing facilities...... you aren't going to do it at home.
I think he is confused. They are toggle but they do just send a signal to the computer
Old Feb 5, 2019 | 07:04 PM
rob0225's Avatar
rob0225
Thanks. I was hoping I could convert it. I was bale to convert one on my Harley by removing a clip inside the switch. Just got done taking this one apart and understand the construction better now, no way to convert it easily.
Does anyone know of toggle switches of this design and form factor, I'd even re purpose one if it's a toggle.
Old Feb 6, 2019 | 06:23 PM
MoparFanatic21
I'm using facturer switches to control a Katzkin heated and cooled seats
Old Feb 6, 2019 | 06:59 PM
rob0225's Avatar
rob0225
Can you elaborate? Which switches and how are you doing it?
Does anyone know if the sway bar switch is momentary or doe sit stay on the up and down position when pressed?
Old Feb 7, 2019 | 06:46 AM
rob0225's Avatar
rob0225
They aren't momentary they are toggle switches.
Understand they aren't toggle switches in the traditional sense of having a single pole that toggles up and down. Only inferring that when pushed the switch does not remain in the up or down position it returns to center automatically after push either up or down.
Old Feb 10, 2019 | 10:25 AM
MoparFanatic21
Yes because it sends a signal to the module. I understand why you are saying lol. I used factory Dodge heated and cooled seats buttons and just tapped into the wire after the module.
