4x4 isn’t working
Old Feb 18, 2019 | 11:05 PM
denysb's Avatar
denysb
Default 4x4 isn’t working
I have a 2006 Ram 1500 4.7 4x4 but whenever I try to turn on my 4x4 I don’t hear it engaging and no lights come up on my dash saying it’s on
Old Feb 19, 2019 | 08:09 AM
Checked for blown fuses? Has it ever worked?
Old Feb 19, 2019 | 10:16 PM
denysb's Avatar
denysb
I have checked the fuses and they don’t seem to blown and the pervious owner say that the 4x4 has worked but they said the computer had to be reprogrammed at the dealership but I don’t know much about 4x4 so I can’t say if that’s true or not
Old Feb 21, 2019 | 06:38 PM
72rtchallenger's Avatar
72rtchallenger
4wd switch or shift motor could be issues to check also the tccm
Old Feb 24, 2019 | 05:27 PM
Mrwall1's Avatar
Mrwall1
Default 2005 3500 dodge ram
When my four wheel switch is turned to 4x4, it flashes , indicator light comes on but does not go into 4 wheel drive. Any suggestions?
Old Feb 24, 2019 | 05:42 PM
72rtchallenger
shift motor is first thing to check,,on my 04 the shift motor plug had water moisture in it when unplugged, it poured water when unplugged out on motor side, faulty design ,,check that and shift motor is usually the issue,,to pull chassis codes you need a good hand held that can read chassis codes
