Mystery wire
Old Mar 26, 2019 | 11:58 AM
THRobinson's Avatar
THRobinson
Default Mystery wire
Still having some startup issues... now that the snow is gone and getting warmer here in Canada I can actually start troubleshooting.
Saw a YouTube vid, someone had the same issue (truck starts, runs 2 seconds, dies. No sputtering, coughing, smoke. Runs fine for 2 seconds then dies) and in his case it was a bad battery connection.
Popped the hood and had a look and connection looks ok, though no idea how good the wiring is inside the plastic sleeve. However, there is a wire, about 10" long, a bit coiled with a spade connector on the end, just there... can't see where it should go, no idea what it's for... maybe the issue?
Anyone know where the mystery wire goes?
Old Mar 27, 2019 | 06:42 PM
GRNDPNDR's Avatar
GRNDPNDR
I don't know what it is but it's not factory because OEMs don't use those spade connectors.
Follow the wire and see where it goes. It was likely something the previous owner added.
Old Mar 28, 2019 | 07:55 AM
Thats not factory. Agree with the above advise. Follow the wire and see where it goes.
Old Mar 28, 2019 | 09:20 AM
THRobinson's Avatar
THRobinson
I think it goes there, like, spliced in at that spot, wrapped around the cable a few times and just dangles.
The white one has a spade connector going to the terminal, so thought this one went somewhere as well, but, just there. Worried they may have damaged the harness splicing it in.
I don't have a pic (raining right now, will get it later) but there is also a yellow "mystery wire" hanging out of the harness that runs along under the wipers at the passenger side.
Also apparently a 3rd party remote starter installed. Never tried it, I don't use them and remote battery dead. Hear that they sometimes cause startup issues and would like it removed, just need to research them a bit first to know where it would be and what it looks like.
Sadly, the Ram this year will need a lot of small things done.
