bleeding brakes after replacing wheel cylinder
Old Apr 22, 2019 | 04:03 PM
Matcbaker's Avatar
Matcbaker
New Member
Default bleeding brakes after replacing wheel cylinder
Hi I have a 94 Dodge Ram Van B350 that I changed the rear right wheel cylinder. When I removed the brake line from the wheel cylinder no fluid leaked out and the front well of the master cylinder was empty.
What order of operation should I take to bleed the brakes?
Thanks'
Matt Baker
Old Apr 22, 2019 | 05:01 PM
fj5gtx's Avatar
fj5gtx
You should bleed the master cylinder first. Then work your way around the car, longest (brake line) distance from teh master cyl to the shortest. If you have a leak, fix that first.
