New stereo install, constant wire won't work
Old Jul 23, 2019 | 01:25 PM
matthew frantz's Avatar
matthew frantz
Default New stereo install, constant wire won't work
So, I decided I wanted a new radio in my 2003 Dodge ram 1500, the previous owner had messed up the wires, so I couldn't get a new wire harness. I cut the old harness off, and used butt connectors to attach the new harness. I am positive that I connected the wires correctly. After everything was connected, I plugged in the new radio and, nothing. I went back and found out that the constant wire was completely dead. There were no rips in the wires, and I tested all the fuses which were fine. Idk if the wire is fried or not, if so what should I do?
Old Jul 23, 2019 | 06:24 PM
jrsick's Avatar
jrsick
If you have a probe you can check the fuse panel, find a constant dc source, and tap in. Or, you can run a wire directly to the battery, just be sure to fuse it. If you are installing an amp anyway you can run the amp wire and constant together.
Old Jul 24, 2019 | 07:47 AM
72rtchallenger's Avatar
72rtchallenger
Old Jul 24, 2019 | 10:07 AM
ol' grouch's Avatar
ol' grouch
I'm not a fan of butt connectors. I prefer to twist the wires together, solder them and then insulate with black tape. I dread getting a vehicle where a kid took a system out. They usually hack it in and then slash it out. Then again, when I was a kid, there was 3 maybe 4 wires to a radio.
Old Jul 24, 2019 | 10:54 PM
matthew frantz
Replaced the fuse 51, radio works now. Thanks for all the help though!
