Broken spark plug!!!!
Old Aug 14, 2019 | 05:04 AM
Distrut's Avatar
Distrut
Default Broken spark plug!!!!
Hello, I have an 04 dodge ram 1500 with a 4.7. I was changing plugs and coil packs well the number 8 plug broke. Luckily all the porcelain came out. So my question is I was told by one person to use a #5 easy out while another said to use a #6 which one should I use it is the spiral kind not the fluted kind? What kind of pressure should I expect to put on the easy because I don’t want to break the easy out inside the spark plug? Or if anyone has any better options I am all ears.
Thanks
Old Aug 14, 2019 | 07:44 AM
ZEN357's Avatar
ZEN357
I would invest in one of these before I used an easy out.... I know it says for the Ford 5.3 Trition but it may work for the Dodge 4.7 OHC Engine.
https://www.jegs.com/i/Lisle-Tools/616/65700/10002/-1
Old Aug 14, 2019 | 07:46 AM
Distrut's Avatar
Distrut
I seen those but was told they would not work on my dodge.
