A pillar / windshield gasket upgrade
Old Sep 14, 2019 | 05:33 PM
fj5gtx's Avatar
fj5gtx
Default A pillar / windshield gasket upgrade
My 04 2500 was first used by the AZ fish and game commission. So at one time it had a spot light (and a hole to support it) on that driver pillar. The gasket was ripped from the door being maladjusted and the hole was overfull of black butyl sealer. I hit the jyard, and found a good 02 two door donor and pulled both sides. But on my way through the yard, I stopped by a 07 two door - and found that they had made quite a few alterations to those seals. I pulled the 07, tried them on the 02 donor - good to go...
I just installed them on my truck, they match up fine. I can't say they're better, because the originals were a mess, but they look like they should work better. If you want to upgrade, you'll need the rubber gasket and the plastic adapter it attaches to.
Old Sep 15, 2019 | 09:14 AM
rebeltaz83's Avatar
rebeltaz83
Nice to see they up dated the door seals. They are both torn on my 05, have been since I bought it 5 years ago. Corner of the door eats them up. Wonder if they changed in 06 with the front clip and tail lights??
Old Sep 16, 2019 | 01:08 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
There were two TSB's that covered this:
http://dodgeram.info/tsb/2005/23-005-05.htm
http://dodgeram.info/tsb/2005/23-049-05.htm
Old Sep 16, 2019 | 10:09 PM
fj5gtx's Avatar
fj5gtx
Originally Posted by Magnoom
That is cool, I did notice the lower seal was different - but figured I would not have the holes it required... and sure enough, it says drill a hole.
