Starting Issues
Old Oct 20, 2019 | 01:25 AM
Meezer's Avatar
Meezer
Default Starting Issues
I'm having starting issues with my 03 2500 5.7L
When I try to start it in the morning, as soon as I turn the key it starts right up. Anytime after the initial start, it cranks for 6-7 long seconds before it starts. Park it for the night, next morning starts up as soon as I turn the key. Rest of the day, starts up after cranking for 6-7 seconds. Anyone have any ideas on what may be causing these staring issues?
Old Oct 20, 2019 | 06:22 AM
fj5gtx's Avatar
fj5gtx
How many miles on it?
Is there a difference in the ambient temperature when its delayed vs when its not?
When is the last time you cleaned the throttle body and changed the plugs?
Have you put a code reader on it to see if its flagging anything?
Do a web search on 5.7 hemi warm hard start. You'll find people theorizing that its the injectors leaking, and that causes it to be too rich. Sitting for long time lets the fuel evap off I guess. Also they say a faulty coolant temperature sensor can cause that.
Old Oct 20, 2019 | 07:50 AM
TrueDogman's Avatar
TrueDogman
I can confirm this theory first hand. Lol
however it was a Dodge 3.5l v6.
Old Oct 20, 2019 | 10:32 AM
Alex Medeiros's Avatar
Alex Medeiros
Any chance bad gas could be a factor? As in does the truck run and drive fine after started? I'm assuming that it drives fine and all, but just struggles to start up?
Old Oct 20, 2019 | 10:42 AM
Meezer's Avatar
Meezer
The engine was rebuilt 3 years ago & now has approximately 65,000 miles on it. Temps in morning when I initially start it range from the upper 30's to 50's.
I have not put a code reader on it.
Old Oct 20, 2019 | 10:45 AM
Meezer's Avatar
Meezer
It is my work truck & I fill the tank at least twice a week from different gas stations. The truck runs & drives fine after it's started.
Old Oct 20, 2019 | 06:58 PM
fj5gtx's Avatar
fj5gtx
New temp sensor would be fast to swap... if not joy, then check the injectors.
Old Dec 29, 2019 | 08:07 PM
Meezer's Avatar
Meezer
Update: I had it scanned & it was the Camshaft Sensor. Had it replaced & it's all good!
Old Dec 30, 2019 | 02:36 PM
TrueDogman's Avatar
TrueDogman
Thanks for letting us all know. Good stuff
