Help with fuse location!
Old Jan 10, 2020 | 06:45 PM
Skipper33569's Avatar
Skipper33569
Default Help with fuse location!
I own a 2005 Dodge Ram all wheel drive pickup and am have an issue with the Service 4 Wheel Drive light staying on. I was on the process of replacing the transfer case shift motor when I found two of the wires going to the seven pin plug with their insolation worn through. Now, I'm not sure of it's the motor or a blown fuse that's causing the issue. Can someone point me in the direction of where the power fuse for the shift motor is located? I could also use info on wire colors going to the shift motor. Thanks in advance.
