Code P0138
Old Jan 19, 2020 | 12:36 AM
Charleston Jourdan's Avatar
Charleston Jourdan
Default Code P0308
The only things that appeared to exceed its parameter are the 02 sensors. I don’t think they should exceed 1 volt. Shouldn’t it be 0.1 to 0.9 volt? Can someone help me interpret what could be the issue here:
Vehicle Information (Mode 09)
Description
Count
Vehicle Identification Number (VIN)
1D7HA18NX8J114055
Calibration Identifications (CALID)
05094374AE
Calibration Verification Numbers (CVN)
AB3036A3
In-use Performance Tracking (IPT)
OBD Monitoring Conditions Encountered Counts
258
Ignition Cycle Counter
745
Catalyst Monitor Completion Counts Bank 1
0
Catalyst Monitor Conditions Encountered Counts Bank 1
2
Catalyst Monitor Completion Counts Bank 2
0
Catalyst Monitor Conditions Encountered Counts Bank 2
2
O2 Sensor Monitor Completion Counts Bank 1
0
O2 Sensor Monitor Conditions Encountered Counts Bank 1
2
O2 Sensor Monitor Completion Counts Bank 2
0
O2 Sensor Monitor Conditions Encountered Counts Bank 2
2
EGR Monitor Completion Condition Counts
0
EGR Monitor Conditions Encountered Counts
2
AIR Monitor Completion Condition Counts (Secondary Air)
0
AIR Monitor Conditions Encountered Counts (Secondary Air)
0
EVAP Monitor Completion Condition Counts
42
EVAP Monitor Conditions Encountered Counts
79
ECU Name
No data reported by car
System Status (Mode 01)
Description
OBD Type
OBD Type
OBD (Federal EPA)
Trouble Codes
MIL Status
Off
Number of DTCs
0
Continuous Monitoring tests
Misfire
Supported
Complete
Fuel System
Supported
Complete
Comprehensive Components
Supported
Complete
non-Continuous Monitoring tests
Catalyst
Supported
Not Complete
Heated Catalyst
Not Supported
Evaporative System
Supported
Not Complete
Secondary Air System
Not Supported
A/C System Refrigerant
Not Supported
Oxygen Sensor
Supported
Not Complete
Oxygen Sensor Heater
Supported
Not Complete
EGR System
Supported
Not Complete
Fuel System Status
Fuel System 1 Status
closed loop
Fuel System 2 Status
closed loop
Diagnostic Trouble Codes (Mode 03, 07, 0A)
Description
Stored Diagnostic Trouble Codes (DTC) (Mode 03)
No Trouble Codes
Pending Diagnostic Trouble Codes (DTC) (Mode 07)
No Trouble Codes
Permanent Diagnostic Trouble Codes (DTC) (Mode 0A)
No Trouble Codes
Freeze Frame Data (Mode 02)
Description
Value
Units
P0308 - Cylinder 8 Misfire Detected
03 - Fuel System Status
Fuel System 1
closed loop
Fuel System 2
closed loop
04 - Calculated Load Value
20
05 - Engine Coolant Temperature
196
°F
06 - Short Term Fuel Trim - Bank 1
-1.6
07 - Long Term Fuel Trim - Bank 1
-3.1
08 - Short Term Fuel Trim - Bank 2
-7.0
09 - Long Term Fuel Trim - Bank 2
-7.8
0B - Intake Manifold Absolute Pressure
8.9
psi
0C - Engine RPM
211
rpm
0D - Vehicle Speed
20
mph
0E - Ignition Timing Advance for #1 Cylinder
8
0F - Intake Air Temperature
59.00
°F
11 - Absolute Throttle Position
12.2
1E - Power Take Off Status
OFF
1F - Time Since Engine Start
00:13:51
2C - Commanded EGR
0.8
2D - EGR Error
0.0
2E - Commanded Evaporative Purge
32.5
2F - Fuel Level Input
23.9
33 - Barometric Pressure
29.2
inHg
42 - Control module voltage
14.654
V
43 - Absolute Load Value
18.8
44 - Commanded Equivalence Ratio
0.999
45 - Relative Throttle Position
1.6
46 - Ambient air temperature
57
°F
47 - Absolute Throttle Position B
11.8
49 - Accelerator Pedal Position D
8.6
4A - Accelerator Pedal Position E
4.3
4C - Commanded Throttle Actuator Control
1.2
Location of Oxygen Sensors
State
Bank 1 - Sensor 1
Present
Bank 1 - Sensor 2
Present
Bank 1 - Sensor 3
Not Present
Bank 1 - Sensor 4
Not Present
Bank 2 - Sensor 1
Present
Bank 2 - Sensor 2
Present
Bank 2 - Sensor 3
Not Present
Bank 2 - Sensor 4
Not Present
Oxygen Sensor Test Results (Mode 05)
Description
Value
Min
Max
Units
Result
Bank 1 - Sensor 1
$00 - No test data available
Bank 1 - Sensor 2
Bank 2 - Sensor 1
Bank 2 - Sensor 2
Oxygen Sensor monitoring test not complete. Data could be invalid.
Monitored Test Results (Mode 06)
Description
Value
Min
Max
Units
Result
TID $91, CID $B6 - Values defined by manufacturer
0.00
0.00
0.00
Pass
TID $07, CID $B6 - Values defined by manufacturer
0.392
0.000
0.392
Pass
TID $08, CID $04 - Values defined by manufacturer
0.666
0.647
65.535
Pass
TID $81, CID $63 - Values defined by manufacturer
0.000
0.000
0.000
Pass
TID $82, CID $10 - Values defined by manufacturer
0
0
0
Pass
TID $83, CID $19 - Values defined by manufacturer
0.000
0.000
0.000
Pass
0.00
0.00
0.00
Pass
0.392
0.000
0.392
Pass
0.705
0.647
65.535
Pass
0.000
0.000
0.000
Pass
0
0
0
Pass
0.000
0.000
0.000
Pass
TID $92, CID $B6 - Values defined by manufacturer
0.00
0.00
0.00
Pass
0.00
0.00
0.00
Pass
TID $93, CID $B6 - Values defined by manufacturer
0
0
0
Pass
TID $94, CID $04 - Values defined by manufacturer
0
0
0
Pass
TID $95, CID $63 - Values defined by manufacturer
-327.68
-327.68
-327.68
Pass
TID $96, CID $10 - Values defined by manufacturer
-327.68
-327.68
-327.68
Pass
TID $87, CID $B6 - Values defined by manufacturer
0.00
0.00
0.00
Pass
0.00
0.00
0.00
Pass
TID $85, CID $B6 - Values defined by manufacturer
0
0
0
Pass
TID $86, CID $04 - Values defined by manufacturer
0
0
0
Pass
TID $90, CID $63 - Values defined by manufacturer
12
12
4300
Pass
TID $83, CID $B6 - Values defined by manufacturer
false
false
true
Pass
TID $84, CID $04 - Values defined by manufacturer
0.00
0.00
100.01
Pass
TID $85, CID $63 - Values defined by manufacturer
0.00
0.00
0.00
Pass
TID $86, CID $10 - Values defined by manufacturer
0.000
0.000
1.999
Pass
TID $87, CID $19 - Values defined by manufacturer
1.000
0.941
65.535
Pass
TID $88, CID $00 - Values defined by manufacturer
0.000
0.000
0.000
Pass
TID $97, CID $B6 - Values defined by manufacturer
5.0
-40.0
125.0
Pass
TID $98, CID $04 - Values defined by manufacturer
0.00
0.00
0.00
Pass
20.0
-40.0
150.0
Pass
0.00
0.00
0.00
Pass
20.0
-40.0
125.0
Pass
0.00
0.00
0.00
Pass
25.0
-40.0
150.0
Pass
0.00
0.00
0.00
Pass
TID $0B, CID $B6 - Values defined by manufacturer
0
0
65535
Pass
TID $0C, CID $04 - Values defined by manufacturer
0
0
65535
Pass
0
0
65535
Pass
0
0
65535
Pass
0
0
65535
Pass
0
0
65535
Pass
0
0
65535
Pass
0
0
65535
Pass
0
0
65535
Pass
0
0
65535
Pass
0
0
65535
Pass
0
0
65535
Pass
0
0
65535
Pass
0
0
65535
Pass
3165
0
65535
Pass
0
0
65535
Pass
0.00
0.00
0.00
Pass
Live Data (Mode 01)
Description Count
1D7HA18NX8J114055
05094374AE
AB3036A3
OBD Monitoring Conditions Encountered Counts 258
Ignition Cycle Counter 745
Catalyst Monitor Completion Counts Bank 1 0
Catalyst Monitor Conditions Encountered Counts Bank 1 2
Catalyst Monitor Completion Counts Bank 2 0
Catalyst Monitor Conditions Encountered Counts Bank 2 2
O2 Sensor Monitor Completion Counts Bank 1 0
O2 Sensor Monitor Conditions Encountered Counts Bank 1 2
O2 Sensor Monitor Completion Counts Bank 2 0
O2 Sensor Monitor Conditions Encountered Counts Bank 2 2
EGR Monitor Completion Condition Counts 0
EGR Monitor Conditions Encountered Counts 2
AIR Monitor Completion Condition Counts (Secondary Air) 0
AIR Monitor Conditions Encountered Counts (Secondary Air) 0
EVAP Monitor Completion Condition Counts 42
EVAP Monitor Conditions Encountered Counts 79
ECU Name
Description
OBD Type
OBD Type OBD (Federal EPA)
Trouble Codes
MIL Status Off
Number of DTCs 0
Misfire Supported Complete
Fuel System Supported Complete
Comprehensive Components Supported Complete
Catalyst Supported Not Complete
Heated Catalyst Not Supported
Evaporative System Supported Not Complete
Secondary Air System Not Supported
A/C System Refrigerant Not Supported
Oxygen Sensor Supported Not Complete
Oxygen Sensor Heater Supported Not Complete
EGR System Supported Not Complete
Fuel System Status
Fuel System 1 Status closed loop
Fuel System 2 Status closed loop
Description
No Trouble Codes
No Trouble Codes
No Trouble Codes
Description Value Units
Fuel System 1 closed loop -
Fuel System 2 closed loop -
04 - Calculated Load Value 20 %
05 - Engine Coolant Temperature 196 °F
06 - Short Term Fuel Trim - Bank 1 -1.6 %
07 - Long Term Fuel Trim - Bank 1 -3.1 %
08 - Short Term Fuel Trim - Bank 2 -7.0 %
09 - Long Term Fuel Trim - Bank 2 -7.8 %
0B - Intake Manifold Absolute Pressure 8.9 psi
0C - Engine RPM 211 rpm
0D - Vehicle Speed 20 mph
0E - Ignition Timing Advance for #1 Cylinder 8 °
0F - Intake Air Temperature 59.00 °F
11 - Absolute Throttle Position 12.2 %
1E - Power Take Off Status OFF -
1F - Time Since Engine Start 00:13:51 -
2C - Commanded EGR 0.8 %
2D - EGR Error 0.0 %
2E - Commanded Evaporative Purge 32.5 %
2F - Fuel Level Input 23.9 %
33 - Barometric Pressure 29.2 inHg
42 - Control module voltage 14.654 V
43 - Absolute Load Value 18.8 %
44 - Commanded Equivalence Ratio 0.999 -
45 - Relative Throttle Position 1.6 %
46 - Ambient air temperature 57 °F
47 - Absolute Throttle Position B 11.8 %
49 - Accelerator Pedal Position D 8.6 %
4A - Accelerator Pedal Position E 4.3 %
4C - Commanded Throttle Actuator Control 1.2 %
Location of Oxygen Sensors State
Bank 1 - Sensor 1 Present
Bank 1 - Sensor 2 Present
Bank 1 - Sensor 3 Not Present
Bank 1 - Sensor 4 Not Present
Bank 2 - Sensor 1 Present
Bank 2 - Sensor 2 Present
Bank 2 - Sensor 3 Not Present
Bank 2 - Sensor 4 Not Present
Description Value Min Max Units Result
Bank 1 - Sensor 1
Bank 1 - Sensor 2
Bank 2 - Sensor 1
Bank 2 - Sensor 2
TID $91, CID $B6 - Values defined by manufacturer 0.00 0.00 0.00 Pass
TID $07, CID $B6 - Values defined by manufacturer 0.392 0.000 0.392 Pass
TID $08, CID $04 - Values defined by manufacturer 0.666 0.647 65.535 Pass
TID $81, CID $63 - Values defined by manufacturer 0.000 0.000 0.000 Pass
TID $82, CID $10 - Values defined by manufacturer 0 0 0 Pass
TID $83, CID $19 - Values defined by manufacturer 0.000 0.000 0.000 Pass
TID $08, CID $04 - Values defined by manufacturer 0.705 0.647 65.535 Pass
TID $92, CID $B6 - Values defined by manufacturer 0.00 0.00 0.00 Pass
TID $93, CID $B6 - Values defined by manufacturer 0 0 0 Pass
TID $94, CID $04 - Values defined by manufacturer 0 0 0 Pass
TID $95, CID $63 - Values defined by manufacturer -327.68 -327.68 -327.68 Pass
TID $96, CID $10 - Values defined by manufacturer -327.68 -327.68 -327.68 Pass
TID $87, CID $B6 - Values defined by manufacturer 0.00 0.00 0.00 Pass
TID $85, CID $B6 - Values defined by manufacturer 0 0 0 Pass
TID $86, CID $04 - Values defined by manufacturer 0 0 0 Pass
TID $90, CID $63 - Values defined by manufacturer 12 12 4300 Pass
TID $83, CID $B6 - Values defined by manufacturer false false true Pass
TID $84, CID $04 - Values defined by manufacturer 0.00 0.00 100.01 Pass
TID $85, CID $63 - Values defined by manufacturer 0.00 0.00 0.00 Pass
TID $86, CID $10 - Values defined by manufacturer 0.000 0.000 1.999 Pass
TID $87, CID $19 - Values defined by manufacturer 1.000 0.941 65.535 Pass
TID $88, CID $00 - Values defined by manufacturer 0.000 0.000 0.000 Pass
TID $97, CID $B6 - Values defined by manufacturer 5.0 -40.0 125.0 Pass
TID $98, CID $04 - Values defined by manufacturer 0.00 0.00 0.00 Pass
TID $97, CID $B6 - Values defined by manufacturer 20.0 -40.0 150.0 Pass
TID $97, CID $B6 - Values defined by manufacturer 20.0 -40.0 125.0 Pass
TID $97, CID $B6 - Values defined by manufacturer 25.0 -40.0 150.0 Pass
TID $0B, CID $B6 - Values defined by manufacturer 0 0 65535 Pass
TID $0C, CID $04 - Values defined by manufacturer 0 0 65535 Pass
TID $0B, CID $B6 - Values defined by manufacturer 3165 0 65535 Pass
Description Value Units Min Average Max
Fuel System 1 open loop - 1.00 1.00 1.00
Fuel System 2 open loop - 1.00 1.00 1.00
04 - Calculated Load Value 0 % 0.00 0.00 0.00
05 - Engine Coolant Temperature 205 °F 204.80 204.80 204.80
06 - Short Term Fuel Trim - Bank 1 0.0 % 0.00 0.00 0.00
07 - Long Term Fuel Trim - Bank 1 -1.6 % -1.56 -1.56 -1.56
08 - Short Term Fuel Trim - Bank 2 0.0 % 0.00 0.00 0.00
09 - Long Term Fuel Trim - Bank 2 -7.0 % -7.03 -7.03 -7.03
0A - Fuel Rail Pressure NO DATA psi 0.00 0.00 0.00
0B - Intake Manifold Absolute Pressure 29.2 psi 29.23 29.23 29.23
0C - Engine RPM 0 rpm 0.00 0.00 0.00
0D - Vehicle Speed 0 mph 0.00 0.00 0.00
0E - Ignition Timing Advance for #1 Cylinder -64 ° -64.00 -64.00 -64.00
0F - Intake Air Temperature 60.80 °F 60.80 60.80 60.80
10 - Air Flow Rate NO DATA lb/min 0.00 0.00 0.00
11 - Absolute Throttle Position 17.6 % 17.65 17.65 17.65
12 - Commanded Secondary Air Status NO DATA - 0.00 0.00 0.00
14 - Bank 1 - Sensor 1
Oxygen Sensor Output Voltage 0.800 V 0.01 0.31 0.80
Short Term Fuel Trim 0.0 % 0.00 0.00 0.00
15 - Bank 1 - Sensor 2
Oxygen Sensor Output Voltage 1.270 V 0.06 0.54 1.27
Short Term Fuel Trim 99.2 % 99.21 99.21 99.21
3C - Catalyst Temperature Bank 1, Sensor 1 -40.0 °F -40.00 -40.00 -40.00
3D - Catalyst Temperature Bank 2, Sensor 1 -40.0 °F -40.00 -40.00 -40.00
3E - Catalyst Temperature Bank 1, Sensor 2 NO DATA °F 0.00 0.00 0.00
3F - Catalyst Temperature Bank 2, Sensor 2 NO DATA °F 0.00 0.00 0.00
Last edited by Charleston Jourdan; Jan 19, 2020 at 10:04 PM. Reason: Error: The actual code is 0308 not 0138
Old Jan 19, 2020 | 09:14 AM
What year and what engine?
Old Jan 19, 2020 | 04:03 PM
Charleston Jourdan
2008 ram 1500; 4.7
Old Jan 19, 2020 | 04:10 PM
Charleston Jourdan
Default That’s before I cleared the code
Description
OBD Type
Trouble Codes
MIL Status On
Number of DTCs 1
Comprehensive Components Supported Complete non-Continuous Monitoring tests
Evaporative System Supported Complete
Oxygen Sensor Heater Supported Complete
EGR System Supported Not Complete Fuel System Status
Fuel System 2 Status closed loop Description Stored Diagnostic Trouble Codes (DTC) (Mode 03)
Vehicle Area: Powertrain (P)
Area of Vehicle System: Ignition System or Misfire
Controlled by: ISO/SAE Controlled Code (Core DTC)
Controll Unit: $7E8 - CAN-ID ECU #1 Pending Diagnostic Trouble Codes (DTC) (Mode 07)
Controll Unit: $7E8 - CAN-ID ECU #1 Permanent Diagnostic Trouble Codes (DTC) (Mode 0A)
No Trouble Codes Description Value Units P0308 - Cylinder 8 Misfire Detected
4C - Commanded Throttle Actuator Control 1.2 % System Status (Mode 01) Diagnostic Trouble Codes (Mode 03, 07, 0A) Freeze Frame Data (Mode 02)
Old Apr 11, 2020 | 02:18 PM
StickyHands's Avatar
StickyHands
Question 2013 Charger dct P0138
I am having a similar issue getting the P0138, which identifies O2 Bank 1 Sensor 2 as the culprit. What I am looking for is to know which side, left or right, and which sensor, before or after the cat, is being referred to. Can anyone help me?
Old Apr 11, 2020 | 04:28 PM
https://www.o2sensors.com.au/static/...-and-locations
Old Apr 12, 2020 | 10:22 AM
StickyHands
@jkeaton Thank you!
