Starter Replacement Question.
Old Mar 6, 2020 | 11:37 AM
Joseph Matthew Photography's Avatar
Default Starter Replacement Question.
I just got my truck back from getting a replacement motor installed by my friend he did a great job. The truck runs amazing. Picked it up last night and filled it with gas drove home and go to take the kids to school this morning and it would not start. The starter was not engaging just made a sound like it was stuck or grinding the fly wheel. I pulled the starter this morning and it looks like it might need to be replaced again. I replaced it last year with an auto zone reman. it has a life time warranty so I am headed in to test and exchange this one.
When I was pulling the starter I forgot to disconnect the battery and when I was pulling off the small nut for the starter solenoid it sparked. Anything I could have damaged? Anything I should check after I install the new starter? I looked at the starter fuse #14 under the hood and it seemed okay. going to pick up another incase it needs replacing. Battery seems fine truck still has power. I disconnected the battery for now and pulled the starter. Anything else that could be causing this grinding noise or issue when trying to start the truck?
Old Mar 6, 2020 | 12:19 PM
TrueDogman's Avatar
TrueDogman
You have the starter off so start with checking that. However you may have an issue with the starter ring gear on the flex plate of the truck. The gear on the starter meshes with the starter ring gear on the flex plate. You may need to look in the starter opening to check that ring gear.....all the way around by manually turning the engine over.
There MAY be 2 fuses you need to check. A main start fuse and possibly a smaller starter relay fuse
Old Mar 6, 2020 | 02:23 PM
I pulled the starter and took it to auto zone to have it tested since I recently purchased it and the starter had a lifetime warranty. The starter was not engaging causing the grinding sound it was only going about halfway out and not fully spinning. They tested it on their testing machine and it failed twice. They replaced the starter for free I installed it in about 10 minutes reconnected the battery and the truck was running like brand new. I was lucky and did not damage any fuses or relays. Last time I ever replace a starter without disconnecting the battery.
Old Mar 6, 2020 | 02:33 PM
TrueDogman's Avatar
TrueDogman
Great news. Thanks for the update
