Purge solenoid Vacuum Hose locations ? 2005 4.7 1500
Old Mar 14, 2020 | 11:13 PM
Hasberry's Avatar
Hasberry
Default Purge solenoid Vacuum Hose locations ? 2005 4.7 1500
Can someone tell me which vacuum hose connection going to the purge valve on my 2005 ram 1500 4.7 goes to the throttle body ? The upper nipple or the Lower nipple on the purge valve ? which one connects to the throttle body. I had a vacuum leak and had to splice into the 2 vacuum lines going into the purge valve . I can not remember which line went where. I connected the upper nipple line to the Throttle body in the pic.
Old Mar 16, 2020 | 02:44 PM
Hasberry's Avatar
Hasberry
Never mind I figured it out. The purge valve is labeled on one of the ports.
Old Sep 22, 2023 | 10:31 PM
KJM's Avatar
KJM
So which one IS the Throttle body as my purge valve is not labeled and I did the same thing.
Old Sep 24, 2023 | 04:20 PM
FabricGATOR's Avatar
FabricGATOR
Too bad this thread was incomplete or you (we) would already have the answer you seek...
Hey, if you would... when you find the answer, please return and tell the world!
Cheers, and thank you for your anticipated reply.
