speedometer & tachometer
Old May 4, 2020 | 07:49 PM
moonshot's Avatar
moonshot
Default speedometer & tachometer
It took for ever to charge batteries and jump start 2005 3500 diesel. When it finally started . I noticed the speedometer & tach where on the back side of the pin .How do i fix this problem and can i drive the truck this way.
Old May 5, 2020 | 12:58 AM
Alex Medeiros's Avatar
Alex Medeiros
Try holding the trip button in front of the instrument cluster and turn the key to the on position/accessories mode (right before you actually start the truck) 3 times. On the third turn leave the key to the on position and let the truck do a test. I included a link to a video showing you how to do it. It may reset your needles back to their correct positions...
Old May 5, 2020 | 04:52 AM
tryNto's Avatar
tryNto
You combined both tests into 1 operation.
For the EMIC test, Just hold in the trip button in front of the instrument cluster and turn the key to the on position, this will start the sequence. (Chassis Codes)
The turn the key 3-time thing is for showing DTCs. turn key from off to on 3 times, leaving the key in on position the 3rd time. (Powertrain Codes)
Codes will show in the odometer area and will read DONE when finished.
OP: won't hurt anything driving like that.
The EMIC test may reset them.
Old May 5, 2020 | 01:43 PM
Alex Medeiros
Ah shoot I guess I mixed it up. Thanks for the correction
