C-code list for 3rd gen rams. Does anyone have this info?
Old Jun 11, 2020 | 11:17 AM
sb318wedge's Avatar
sb318wedge
Default C-code list for 3rd gen rams. Does anyone have this info?
Not sure what these codes are but I’m trying to find out why my remote start isn’t working
(2007 Ram 5.7 hemi 4x4, with traction control)
thanks
1st display
2nd display
3rd display then it repeats
Old Jun 11, 2020 | 11:52 AM
GRNDPNDR's Avatar
GRNDPNDR
Unfortunately there isn't a list that includes ALL of the codes for some reason, but this is the most comprehensive one I've been able to find.01 Airbag warning indicator output circuit shorted.
66 All door lock output circuit shorted to ground or voltage.
02 Airbag warning indicator output circuit open.
67 All door unlock output circuit shorted to ground or voltage.
03 ABS indicator output circuit shorted.
68 Driver door unlock output circuit shorted to ground or voltage.
04 ABS indicator output circuit open.
6C Driver cylinder lock switch input circuit shorted.
05 MIL indicator output circuit shorted.
6E Driver cylinder lock switch input circuit stuck.
06 MIL indicator output circuit open.
80 Incorrect odometer value found.
07 Wait to start indicator circuit shorted.
81 Remote radio switch input circuit high.
08 Wait to start indicator circuit open.
82 Remote radio switch stuck.
0B BTSI output circuit shorted or open.
A0 Internal module FLASH memory checksum failure.
22 Headlamp switch input circuit shorted.
A1 Internal module bootloader failure.
23 Headlamp switch input circuit open.
A3 Battery voltage open.
24 Turn hazard switch input circuit shorted.
A5 TCCM messages not received.
25 Turn hazard switch input circuit open.
A7 VIN checksum error.
27 Courtesy/dome output circuit shorted or open.
A8 VIN previously stored.
28 Glovebox/map lamp output circuit shorted or open.
A9 PCI bus internal failure.
29 Cargo lamp output circuit shorted or open.
AA PCM messages not received.
40 Wiper switch input circuit shorted.
AB TCM messages not received.
41 Wiper switch input circuit open.
AC ABS messages not received.
42 Wash/beam input circuit shorted.
AD FCM messages not received.
60 Passenger door lock switch input circuit shorted.
AE ACM messages not received.
61 Passenger door lock switch input circuit open.
AF SKIM messages not received.
62 Passenger door lock switch input circuit stuck.
B0 RKE fob batteries low.
63 Driver door lock switch input circuit shorted.
B1 RKE module communication link.
64 Driver door lock switch input circuit open.
00 Done All Diagnostic Trouble Codes have been displayed.
65 Driver door lock switch input circuit stuck.
