2007 3.7 magnum engine swap trans capacity
Old Jun 22, 2020 | 11:11 PM
Vicarroyo5903's Avatar
Vicarroyo5903
Default 2007 3.7 magnum engine swap trans capacity
Hi,I’m running a 2007 ram with a 3.7 magnum v6 is it possible to upgrade the engine to the 4.7 v8 with the same trans?
Old Jun 23, 2020 | 10:03 AM
drummerchuckb1's Avatar
drummerchuckb1
I *think* the 3.7L comes with the 42RLE transmission. I would search for torque and power ratings of that transmission and compare to the output of the 4.7L. My assumption is you will want the 45RFE transmission to handle the 4.7L output for long term durability. But there are other aspects to consider as well which I don't know the answers to, like if the 4.7L will bolt to the 42RLE or if you will need a transmission adapter. Does the same computer control the engine and the transmission? That could be a significant hurdle as well if you try to mix and match engine and trans. Maybe someone else here knows better than I do and can chime in.
Old Jun 23, 2020 | 11:38 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
You'd have to, 4.7 PCM won't run a 42RLE. Also the RLE won't hold the 4.7's torque; there's a reason it was never offered with it. So if you swap to a 4.7, you have to swap the RFE with it.
Old Jun 24, 2020 | 12:35 AM
Vicarroyo5903
[QUOTE=Magnoom;3484871]You'd have to, 4.7 PCM won't run a 42RLE. Also the RLE won't hold the 4.7's torque; there's a reason it was never offered with it. So if you swap to a 4.7, you have to swap the RFE with it.[/QUOTE I have my answer now thanks
