Overhead console wires
Old Jul 20, 2020 | 09:32 PM
gr8scott72's Avatar
gr8scott72
Default Overhead console wires
Does anyone know what the wire colors are for the overhead console? I am wanting to hard wire the power for a dash cam and hoping 2 of those are power and ground. 2006 mega cab
Old Jul 21, 2020 | 08:23 AM
GRNDPNDR's Avatar
GRNDPNDR
I don't have the pinouts handy at the moment, but just get a meter and start testing the wires. I'll see if I can find something from my 05 manual.
I've tapped into these wires before, there should be a +12V and G
EDIT
Here you go
Old Jul 21, 2020 | 08:31 AM
GRNDPNDR's Avatar
GRNDPNDR
errrrr..... those colours don't match.....well BK/WT does, so that's ground.
Old Jul 21, 2020 | 06:39 PM
gr8scott72's Avatar
gr8scott72
Yeah, those don't match what I have. The black/white is ground and the gray/red is +12v but I can't determine what the other 2 are. Key on or off doesn't seem to change the voltage any.
Old Jul 21, 2020 | 08:31 PM
GRNDPNDR's Avatar
GRNDPNDR
the colours may be different but the pins should still be the same.
Old Jul 24, 2020 | 01:36 PM
gr8scott72's Avatar
gr8scott72
The outer two are ground and constant 12v.the inner two and twisted together and both read about 4v.
Anyways, I just ended up running a switched power line all the way to the fuse box instead.
