Stock 20"
Old Aug 10, 2020 | 11:13 PM
bovallar's Avatar
bovallar
Default Stock 20"
Hello guys I need some advice, I would like to know if 275 65r20 tires fits a 2008 Ram 1500 2wd with no modifications on stock 20" wheels? Thanks.
Old Aug 11, 2020 | 07:16 PM
fj5gtx's Avatar
fj5gtx
They should. You could order a truck with 275 60 r20s. Look around for pictures of 2wd trucks on the internet, I think you'll find them.
Old Aug 11, 2020 | 07:46 PM
theuscfan04's Avatar
theuscfan04
They fit fine. That's what I have on my truck.
Old Aug 12, 2020 | 09:29 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
It's one step up in tire height, you'll be fine, just a taller sidewall. 02-03 the stock 20 was 275/55, then 2004 changed it to 275/60 well into the 4th gen run.
Old Aug 12, 2020 | 09:40 AM
bovallar's Avatar
bovallar
Ok..thanks, and what happen if instead of 275 65 20 I put 285 65 20, will it fit with no problem? Thanks again for your advice.
Thanks everybody for your comments.
Old Aug 13, 2020 | 12:44 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
You might be pushing it at that height, the width is fine, if a bit bulgy on a factory 20x9 wheel. The 275/65 is only about an inch taller than the 275/60, but the 285/65 is a little over an inch and half taller than the 275/60. Assuming you have stock 20's with the stock size 275/60's on it, you need to turn it to full lock, add 3/4" past the tire and see if that's gonna hit anything.
