I want to install inline fuel check
Old Aug 31, 2020 | 08:46 PM
willie16wild's Avatar
willie16wild
Default I want to install inline fuel check
I want to install an inline fuel check valve in the line leading up to the fuel rail. Where in the line should I install it?
I am mostly having trouble figuring out which line it is. So a picture would be greatly appreciated.
And is it 5/16 or 3/8 line?
I have 2005 dodge ram 1500 5.7L
Old Aug 31, 2020 | 09:43 PM
fj5gtx's Avatar
fj5gtx
Shouldn't need to, what are you trying to fix?
Old Sep 7, 2020 | 11:51 AM
axelrodmotorhead@yahoo.com's Avatar
Default Fuel check
Spoiler
I have 2005 dodge ram 1500 5.7L[/QUOTE]
Old Sep 7, 2020 | 12:05 PM
audiowize's Avatar
audiowize
Yeah, why would you want to put a check valve in? If you have a real problem, you'll want to address that.
Old Sep 7, 2020 | 06:59 PM
Default Fuel check valve
I just got done putting in a tank unit in a 2001 Ram 1500 with 5.9 liter. Couple hour job taking your time Cured the problem of not having stored fuel pressure. Owner had to turn key on n off 3 times before cranking to build up pressure. New carter pump cured the pressure issue
Old Sep 8, 2020 | 08:23 AM
Are you also willie16wild?
