No lower Brake lights
Old Sep 29, 2020 | 03:19 PM
glpro76's Avatar
glpro76
Cool No lower Brake lights
I have a 2005 dodge ram 1500 4.7. I do have running lights and blinkers and flashers. My cab brake light works as well. I have taken the tipm apart and could not see any corrosion in the trace lines. I have replaced the brake switch under the dash. I have changed the park lamp relay to no avail. I have found that fuses 32, 33, 34 related to the brake lights are showing no power. All fuses are showing good. As i said, i swapped the park lamp relay so i assume the relay is good as well. Im about out of options on what to test next. If anyone has any info on testing relay connections or resistance tests. I appreciate any help you can offer.
Old Sep 29, 2020 | 05:53 PM
Alex Medeiros's Avatar
Alex Medeiros
Have you checked your grounds?
Old Sep 29, 2020 | 05:55 PM
glpro76's Avatar
glpro76
I have re-tightened all the grounds related to the tpim went i removed it.
Old Sep 29, 2020 | 05:57 PM
glpro76's Avatar
glpro76
Do you have any other suggestions related to ground?
Old Sep 29, 2020 | 07:02 PM
Alex Medeiros
Make sure you check as many as possible, not just the ones related to the TPIM.
Old Sep 29, 2020 | 07:23 PM
glpro76's Avatar
glpro76
Will do, thanks.
