Windshield washer fluid not spraying
Old Oct 27, 2020 | 10:12 AM
James Wotring's Avatar
James Wotring
Default Windshield washer fluid not spraying
Hello,
I have a 2006 Dodge Cummins, About 2 months ago I noticed my windshield washer fluid was not spraying but I can hear the pump. I tinked with it for a while with no success so I decided to buy a new pump in case the old one was plugged. I put the new one in and same thing. I can hear the pump but does not spray. Any advice?
Thanks
Old Oct 27, 2020 | 10:34 AM
Dodgevity's Avatar
Dodgevity
Originally Posted by James Wotring
Hello,
Thanks
Pull off the lines at the nozzles and see if fluid is pumping. Sometimes the nozzles or lines can clog up. Make sure the lines are all properly connected.
Old Dec 1, 2020 | 05:39 PM
impba15713's Avatar
impba15713
If you ever removed air box washer fluid line may have been pinched after re install of air box.
Been there , issue is more pronounced in the colder weather .
I was getting a slow feed out of mine.
mine is a 04 hemi ,
Check Line from pump to under hood connections.
