Need to replace clutch and bearings in nv3500 2002 Dodge Ram 4.7 what size clutch
Old Nov 6, 2020 | 06:46 AM
Stone Norton's Avatar
Stone Norton
Default Need to replace clutch and bearings in nv3500 2002 Dodge Ram 4.7 what size clutch
I’ve never worked on a manual before, so I’m slightly intimidated, but I’ll figure it out once I get the parts I always do. But I’m not sure if I should order a clutch with a 11 or 12 inch clutch. I don’t want to get the wrong size and have to reorder, I’m trying to order a clutch kit from rock auto if anybody has any opinions about their options, I was going to order the M pact 11 inch kit but then I read some bad reviews and decided on the LUK kit. But the clutch diameter for the LUK is showing like 11-7/8” I’m guessing if I need an 11 the 11-7/8 won’t work. But I’m not really sure.
also it’s not possible to get a kit with the input shaft bearing included is it? It also needs to be replaced. And a normal kit would include the throwout bearing correct? Is their anything else I would need to order to do the job.gaskets special tools ect. Input shaft bearing is definitely bad.
if anyone has any recommendations for clutch kit brands that would also be appreciated. Thank you and if it matters at all the truck is 2wd
Old Nov 14, 2020 | 06:55 PM
Dodgevity's Avatar
Dodgevity
Go on any mopar parts site and search by VIN for the clutch. If it doest tell u the size there, Google the part number.
https://www.moparpartsgiant.com/
