3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
It should fit, do you know the part numbers of both axles?
Gear ratio of new rear will need to be same as front axle.
Be sure to get an anti-spin/LSD rear if you can.
