Losing brake fluid
Old Jan 21, 2021 | 05:59 PM
ToastyMcGhosty's Avatar
ToastyMcGhosty
Default Losing brake fluid
Dads 2005 5.7 Ram is losing brake fluid from the attached photo.Right next to the battery. I dont know a lot about cars so im unsure what its called or how to fix it. Thanks
Old Jan 24, 2021 | 11:30 AM
kejobe's Avatar
kejobe
I would guess thats the abs block. Is it leaking from the line, line/fitting, fitting/block? Could try to tighten it a little and see if it helps. If not then need to replace whatever is leaking.
Old Jan 24, 2021 | 12:34 PM
jrsick's Avatar
jrsick
I recommend wiping the area down with a cloth then getting it dry with brake cleaner. Have someone press on the brake while you watch for the leak. You'll need to know the source of the leak before you can fix it.
