Help!!!
Clean the throttle body sensor cable. Check fuses for throttle body and maybe replace the throttle body/sensor as a last resort. If and when you do, you will want to let the card idle for like 15 minutes after starting it for the first time so the car can relearn the sensor position, etc.
