Pvc
Old Apr 21, 2021 | 12:21 PM
GRed's Avatar
GRed
Default Pvc
Hi Guys, (08 4.7 111k ) got it at 79k ..does anyone know where the pvc valve is located and if it's a twist off vs someone on youtube saying for 06 is a 35mm socket and for the 09 it's a twist off some say it's right side facing the vehicle towards far back... 5.7 shows left of throttle body
just getting prepared for 35k maintenance on some items also planning to spray some penetrating oil on EGR nuts just in case let it sit or on them or a wk or so..any suggestions or other things I should be taking care of or tips would be greatly appreciated
PVC
EGR
Plugs
Oil change & filter
need to replace steering pressure & Return hoses / maybe pump leaking onto hose,,need to investgate
lube ball joints
differential fluid change
trans is already done
UPDATE: Located the PVC valve it's a twist off (easy).. but the EGR is a diff story..I think that's behind the AC unit ??? and looks like hard to get to can anyone verify this would appreciate it.
