2004 1500 Laramie stalled out
Old Apr 22, 2021 | 11:15 PM
Joshua Rumbolt's Avatar
Joshua Rumbolt
Default 2004 1500 Laramie stalled out
My 2004 Laramie has stalled out twice now while driving, didnt make any loud noises, engine just died. Still had power everywhere. Would not restart initially but restarted when held down on the accelerator. Error codes are Intake Air temperature sensor and Thermostat rationality. Any help would be appreciated.
Old Apr 24, 2021 | 10:24 PM
Moparguyram's Avatar
Moparguyram
What engine do u have? Sounds like what happened to my '04 Hemi. It was the crank sensor. Cheap and easy to replace, under $30, located on right side of block and attached to block with 1 bolt, and the wiring harness clip. Took me 5 minutes to swap out.
Old Apr 25, 2021 | 06:25 AM
jrsick's Avatar
jrsick
Since your code says IAT sensor, I recommend you replace that first. It's inexpensive and easy to get to.
Gas mileage will sometimes get very bad right before the IAT goes out.
