2005 Rear End is it a Dana or Mopar?
Old Jan 2, 2006 | 01:55 AM
coryk4's Avatar
coryk4
Default RE: 2005 Rear End is it a Dana or Mopar?
this may be a dumb question but how hard is it to change out the diff. cover.
Old Jan 2, 2006 | 02:47 AM
frogslinger's Avatar
frogslinger
umm... If i remember...
Jack up your rear end. Put a pan under your rear end. Unbolt all the bolts except the top two... watch your fluid drain. Unbolt the last two bolts. Scrape off your "gasket". Put on gasket maker. Bolt on your new cover. Open up the fill hole. Add fluid and friction modifier (as required). Replace fill hole cover.
Old Jan 3, 2006 | 01:09 AM
Mr Mojo's Avatar
Mr Mojo
ORIGINAL: frogslinger
I always check that the fill hole bolt comes out first before draining. You never know.
Old Jan 12, 2006 | 10:53 AM
srenken's Avatar
srenken
What Axle does your 1500 have?
4.56 - DANA (SRT-10)
3.55 - DETROIT AXLE
3.92 - DETROIT AXLE
3.21 - DETROIT AXLE
