Ramrango swap.
Old Jan 11, 2022 | 05:48 AM
Eric Stewart's Avatar
Eric Stewart
Default Ramrango swap.
Hi I've got an AWD 06 durango with a blown 4.7, And recently got an 05 ram 4x4 5.7. The front diff went on it and its winter time up here in Canada and I'm getting stuck EVERYWHERE. I've been told
by DODGE here in courtenay that the front diffs can be swapped. The rear diff is almost pooched as well in the RAM, so my question is can I swap the rear end as well and parts needed? Will that make my RAM then AWD? ALL THE TIME? thx for any help..
Old Jan 11, 2022 | 09:09 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
1. Possibly if it's the corporate 9¼. You'll need to check to see if the spring perches are the same width and if the driveshaft attaches the same way.
2. Putting the front and rear differentials from an AWD Durango does not automatically make your already 4x4 AWD LMAO......that happens in the transfer case.
