Retained Accessory Power (RAP) Wiring
Old Jan 12, 2022 | 02:48 PM
Fredsansoucie's Avatar
Fredsansoucie
Default Retained Accessory Power (RAP) Wiring
So I just installed an aftermarket stereo in my truck, and I temporarily took the ignition power from the 4WD switch. (I have a floor shifter and the wire was there). I would like to get it to retain the RAP, but after looking through the service manual for a while I cannot find any details on wiring. Does anyone know where I can find this? Hoping its something that's not dependent on the CAN bus
Old Jan 12, 2022 | 04:38 PM
SnowBeast428's Avatar
SnowBeast428
It is programming related but if your truck lets you move the windows with the truck off and doors closed after running then you have it. A programmer box is going to be needed, for me I got my acc power from the radio harness by using the harness kits crutchfield sells for your truck, tons of crimp connectors later and its been fine years later.
If you know someone nearby with alfaobd they can add it. Or you can get it yourself and do it.
Old Jan 12, 2022 | 10:05 PM
Fredsansoucie
I have alfaobd and have looked through the configurations but I can't find anything. The service manual wiring diagrams also show nothing on how the power is controlled, whether it be the CAN bus or an actual toggle through the tipm
Old Jan 19, 2022 | 08:05 PM
SnowBeast428
I have college soon but I'll take a look once the horrible laptop i use charges. Alfaobd is a tad convoluted and some of the names dont make sense.
Old Jan 19, 2022 | 08:08 PM
Fredsansoucie
I ended up just going off of the power outlet, for some reason I never thought about it being on the run/acc fuse. My truck does have it though, the radio stayed on before I swapped it out
Old Jan 20, 2022 | 01:31 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Since it isn't mentioned anywhere, what year is your truck?
