05 ram 4.3 need help
Old May 19, 2022 | 11:07 AM
shoskey's Avatar
shoskey
Default 05 ram 4.7 need help
not sure if anyone else has had this issue but ill explain the best i can. my 05 1500 would stall when coming to a stop & this went on for a year. i would clean the throttle body and problem went away. recently cleaned the throttle body and the truck would not even idle. Had DTC for cam pos sensor. replaced the cam sensor now DTC for Crank sensor. replaced crank sensor and did the teach sensor on the scan tool. the truck would idle just fine no issues. when put into gear it now just stalls out no matter what . the truck can sit and idle in park or natural for hours. i replaced all the o2 sensors because i had 1 dead. still no change. no DTCs truck just wont run while in gear.
Old May 19, 2022 | 04:54 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
If you actually have a 4.3 in your 2005 Ram then no one else has ever had this problem.
Old May 19, 2022 | 06:20 PM
95RAM360's Avatar
95RAM360
Could have slop in timing chain…..you need to monitor cam, crank, and rpm signals in wavelength form on a scan tool. This will tell you if those are off
mine did this when my speed sensor on rear diff went bad, but I have a 5.9l
Old May 19, 2022 | 07:21 PM
shoskey's Avatar
shoskey
I went and bought an alta scan tool. the cam and crank signals look good along with rpm signals. Would a stuck Torque convertor cause it to stall?
Old May 19, 2022 | 07:23 PM
shoskey's Avatar
shoskey
My bad 4.7
Old May 20, 2022 | 06:02 AM
95RAM360's Avatar
95RAM360
look good or are they good? They should all be in sync, there’s no in between here, either the wavelength matches with each other or it doesnt
