Serpentine Belt Replacement-Any Side Effects Likely?
Old Aug 20, 2022 | 01:57 PM
JSMCO's Avatar
JSMCO
Default Serpentine Belt Replacement-Any Side Effects Likely?
2008 SLT 4x4 5.7L Hemi 124,000 miles
I am considering replacing my serpentine belt due to mileage but I'm wondering if a new belt may then cause problems with the water pump or idler pulley, etc failing soon after due to the new (tighter, unstretched) belt?
Old Aug 20, 2022 | 02:56 PM
Dodgevity's Avatar
Dodgevity
No. Just replace it.
Old Aug 20, 2022 | 05:29 PM
95RAM360's Avatar
95RAM360
The tensioner will only tension so tight, it will have same about of tension
Old Aug 20, 2022 | 08:26 PM
JSMCO's Avatar
JSMCO
Thanks, makes sense.
Old Aug 21, 2022 | 01:32 PM
Dodgevity's Avatar
Dodgevity
While you got the belt off, do this....
https://dodgeforum.com/forum/2nd-gen...g-pulleys.html
Old Aug 22, 2022 | 08:58 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Water pump should be fine (unless it already has something wrong with it), check your idler pullies to make sure they're still good and your tensioner. It's cheap insurance to get a set but not a requirement to replace the belt. Had a tensioner actually go out on me on a 5.7 and didn't realize it til I was looking at some thing else; never made noise, overheated, alt charged correctly. No symptoms whatsoever.
Old Aug 22, 2022 | 10:41 AM
fj5gtx's Avatar
fj5gtx
My 1500 had one of those plastic idler pulleys deteriorate and ruin the belt. They were pretty inexpensive, I'd replace as part of the belt replacement if they are still original.
