Need part number for the turn signal CONNECTOR/Pigtail
I have to slam my fist on my headlight every startup without fail to get the parking light to work and so its time i replace the bulb, connector, and turn pig tail to fix my splice. Thing is i cant find the pig tail without spending 80 bucks or 60. Does anybody know the part number so i can check ebay for connectors. I have about 2-3cm of wire left on the connector due to my twitchy hands needing to constantly redo the wire strips so i cant just add my own connectors anymore.
Are you referring to the turn signal socket linked below?
https://www.moparfactoryparts.com/oe...228?origin=pla
I found the part I'm looking for. To anyone on the forums use this one, works very well although the heat shrink they give you is too small. Not a big deal tho.
This is the connector+pigtail for the front turn signal and parking lights. I cut mine too short due to twitchy hands and bad wire cutters (Time to figure out how to do snap-on warranty) and this worked flawlessly. No instructions though but i figured it out albeit did miss a part i think but it works.
