3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I replaced my 2004 Ram 3500 driveline fluids at 10K in 2010. The truck now has about 33K on it. So about 23K on the fluids. About 1/2 towing. The fluids have been in there 13 years. Is it time to replace them just based on the length of time they have been in?
They are Amsoil or Mobil 1 depending on the location.
Condensation will introduce moisture in your fluid over years, if you live in an environment with temperature swings. I'd just put some factory spec gear oil in there, since those rear ends will go 300K + miles with simple maint.
