Electronics stability 2008
Old Mar 1, 2024 | 08:53 PM
Bear55's Avatar
Bear55
Default Electronics stability 2008
Hey guys, I’m trying to do a rear end swap in a 2008 1500. Everyone tells me that a electronic stability rear end will not bolt in to a non-electronic stability rear end. I don’t quite understand. maybe someone can get me up to speed with the difference is. Even running the Vin through DealerConnect, it does not tell me whether the vehicle has or doesn’t have electronic stability rear. Little confused here fellas. Keep in mind I’m wanting to change the whole diff not just the ring and pinion. Thanks bunches.
Old Mar 2, 2024 | 04:14 PM
William Scott's Avatar
William Scott
Do you have the users manual ?
