03 Dodge misfire?
Dodge 2500 5.7 has about 160k I have been having stuttering/accelerating problems for the last couple months. Feels like bad gas
comes and goes Have replaced spark plugs 2 O2 sensors pvc valve I think that's the name Throttle body Accelerator pedal cable and sensor Still acting up Codes is PO132 then Misfire Catalyst Evaporative I have no clue where to go from here Could it be catalytic converter? Maybe we bougot bad O2 sensors? Appreciate any guidance love this truck it's been dependable and haven't spent a lot of $ until recently |
What brand O2 sensors? Were you getting that code before you replaced them? What plugs did you install?
03 dodge misfire
I've been reading through several pages trying to gather information
We bought O2 sensors aftermarket don't remember brand I'll try to look for receipts We replaced plugs with iridium? I have noticed copper is recommended The reason replaced plugs was because the truck was just starting to act up |
The iridium plugs may have made the problem worse, not better. :D It's a real crap shoot with the rare earth fellers, some folks have nothing but problems with them, others have no problems at all. Running plain jane coppers is a troubleshooting step in this case.
Going to try the instructions for calibration of pedal
Maybe ground Throttle body We had no codes till after spark plugs installed about a 6 weeks later is when problem really started Then I guess replace spark plugs |
Yup as @HeyYou said these trucks hate anything other than copper plugs. Those aftermarket sensors are also not good to use, as the OEM ones are the best way to go or at least a very highly rated brand.
We could never get the O2 code to reset after replacing sensors
Ill check with dealer Are there only 2 sensors? I thought I read someone mentioned another Thanks for the help |
We recalibrate as we have read in this forum
using Throttle engine light blinked while moving pedal Switched out spark plugs for copper ones still sounds horrible worse in park RPMs jumping all over the place above 35 mph not to bad I guess tomorrow will order Mopar O2 sensors to replace the aftermarket ones we bought any other suggestions? |
In park it runs rough but in gear it sounds better
that should be a clue to help solve problem Any ideas? |
Called dealer to order O2 sensors
they have our Vin # saying we should have 4 o2 sensors We only have 2 have only 2 Dodge ordered them $360 lets hope the code goes out when we put them in Still need ideas why not running correctly |
