02 4.7 mods
Unfortunately these days there isn't much, never really was much so the used market is small. Intake and cams from an 05+ motor might give you a little boost, but not really worth the effort unless you're doing timing chains or something anyway. Custom tuning from a tuner is about it.
Airram.com and that's pretty much it except for this: https://www.boostedtech.com/product/...-supercharger/
You definitely picked the wrong engine to modify unless you like creating custom parts. You can use the heads and cams from the newer 08-12 engines.
08+ cams and intake, throttle body, headers and exhaust , efan conversion, obviously a cold air intake.rear end geared to .392 ,sonnax trans booster and a tuner is what I got done so far. If you really want to get into it then airram.com has things like heads and ect.
