HORN CHIRP DISABLING - 2005 Dodge Ram 1500
Old Sep 23, 2024 | 12:14 PM
Daytona01958's Avatar
Daytona01958
Question HORN CHIRP DISABLING - 2005 Dodge Ram 1500
Hello,
I have a 2005 Dodge Ram 1500 Daytona edition and I would like to disable the horn chirp when using my Remote Keyless Entry (RKE) transmitter (aka: fob). The service manual and owner's manual suggest the following procedure, however, this DOES NOT work for me.
'The horn chirp can be toggled using a scan or by using the Remote Keyless Entry (RKE) transmitter that is already
programmed to the vehicle.
To DISABLE (cancel) the horn chirp feature:
1. Enter the vehicle and close all doors.
2. Fasten the seat belt (this will cancel the seat belt chime).
3. Turn the ignition to the ON position.
4. Press and hold the LOCK button for 4 seconds. Within 6 seconds with the LOCK button still depressed, press
the UNLOCK button. When a single chime is heard, release both buttons.
5. Turn the ignition OFF.
6. Turn the ignition ON or wait 60 seconds.
7. Test the horn chirp feature by pressing the LOCK button.
If a chime is not heard, program mode was canceled before the feature could be disabled. If necessary, repeat the
procedure.
To ENABLE the horn chirp feature, repeat the above procedure.'
I found several different procedures online (including this forum) but have been unsuccessful so far. I was able to switch the door unlock to 1 click unlocks all doors last night, but again the procedure wasn't working and I missed what combination ended up working to get the chime in the dash.
Any ideas?
Thanks in advance.
Old Sep 23, 2024 | 04:13 PM
GrossmeisterB's Avatar
GrossmeisterB
I did it on my car (2004 RAM 1500 Laramie) and it worked. I am not 100% sure but I think it was the same method as you posted here. Maybe you should try it again with different "timing"?
Old Sep 24, 2024 | 08:48 AM
Daytona01958
UPDATE: Got everything to work
UNLOCK SEQUENCE
To toggle between Driver door first and Unlock all doors function:
2. Turn the ignition to the ON position
3. Press and hold the UNLOCK button for 4 seconds. Within 6 seconds with the UNLOCK button still depressed, press the LOCK button
4. Release UNLOCK and LOCK simultaneously, and then press both UNLOCK and LOCK again. A single chime will be heard.
HORN CHIRP DISABLING / ENABLING
To DISABLE the horn chirp feature:
3. Press and hold the LOCK button for 4 seconds. Within 6 seconds with the LOCK button still depressed, press the UNLOCK button
4. Release LOCK and UNLOCK simultaneously, and then press both LOCK and UNLOCK again. A single chime will be heard.
OPTICAL CHIRP (FLASH) DISABLING / ENABLING
To DISABLE (cancel) the optical chirp feature:
3. Press and hold the LOCK button for 4 seconds. Within 6 seconds with the LOCK button still depressed, press the PANIC button
4. Release LOCK and PANIC simultaneously, and then press both LOCK and PANIC again. A single chime will be heard.
To ENABLE the optical chirp feature, repeat the above procedure.
FOB PROGRAMMING (UP TO 4 FOBS)
2. Turn the ignition to the ON position.
3. Press and hold the UNLOCK button on a programmed transmitter for 4 to 10 seconds. Within the 4 to 10 seconds with the UNLOCK button still depressed, press the PANIC button for one second. When a single chime is heard, release both buttons. The chime indicates the system is in program mode.
4. Release UNLOCK and PANIC buttons simultaneously, and then press both UNLOCK and PANIC again. A single chime will be heard.
5. Press and release both the LOCK and UNLOCK buttons simultaneously on a fob to be programmed. A single chime will be heard, this indicates the fob has been recognized.
6. Press and release any button on the same fob. A single chime will be heard, this indicates the fob has been programmed.
7. Repeat steps 5 and 6 for up to a total of 4 fobs.
8. Turn the ignition OFF.
