Projector Headlights...
Old Jan 21, 2006 | 08:57 PM
BeastieBoys21's Avatar
BeastieBoys21
Default RE: Projector Headlights...
whoever manufactures these thing have to hurry the F*** up and get some the the 06 models, those look to damn sweet on cupcakes truck......im jeolous!!!
Old Jan 21, 2006 | 09:12 PM
WingViper's Avatar
WingViper
Sig, why you gettin rid of them, man?
Old Jan 21, 2006 | 10:28 PM
sig's Avatar
sig
I lied them when I bought'em... but after a month i had a change of heart.
Old Jan 21, 2006 | 10:42 PM
sig's Avatar
sig
uh liked. not lied.
Old Jan 22, 2006 | 01:31 AM
WingViper's Avatar
WingViper
Coo, just curious. Not my style but I don't dog on them.
Old Jan 22, 2006 | 02:43 AM
FL_ThunderRoad's Avatar
FL_ThunderRoad
These lights are simple to install, as is removing the stock headlights.
Bare in mind the stock headlights are held in place by 3 bolts. Two in the very front next to the opening where the grill sits. There is one more bolt underneath each light.
These bolts are connected below the orange reflector area in the stock housing. You can reach it by inserting a screwdriver and / or socket adapted between the housing and the bumper.. Just look underneath the stock housing and you will notice the black bolt.
When removing the stock lights be careful not to break the prongs that hold the stock lights in place. Just incase you ever want to put the stock ones back on for any reason.
There after use a circuit tester to be safe and cut two of the three wires connected to you your orange turn signal lights. One is power, One is negative and the third wire I believe is for the blinking of the turn signals. Just ignore that one and stick to the (-) and the (+).
NEVER EVER connect halo rings straight to a battery to test them - THEY WILL BURN OUT!
Being the fact that most halos are really just LEDS attached to a plastic or glass ring.
After you make the adequate connections and the halo rings work. Be sure that you protect those connections from moisture. I used professional electrical tape. Its like a weaved cloth type tape. Simply connected the projector beams to your existing headlight connection plug and replace the screws to the housing.
If you find your projector lights are not that bright, merely upgrade the fog light bulbs to the sylvania 9006 bright white bulbs. These will even out the lack of light.
I also hear that you can swap out the bulbs from the projector housings with better ones. I am about to do this next week. I will take a pic of my housings on my truck. I just installed them today.
Pros: They are very stylish and eye catching. Both at night and during the day!
Cons: Not as bright as stock lights, but simple bulb upgrades will make up for it.
Well best of luck, I will be doing a whole write up later on once I change the projector bulbs with something brighter.
Old Jan 22, 2006 | 04:06 PM
cupcake's Avatar
cupcake
^^ good write up. I didn't do mine as you did yours and All lights worked properly and signals, 2 moneths have gone by and they are all pretty much burnt out and needing to be replaced. Im going to remove them today and find out which bulbs they are and get it taken car of.
Old Jan 24, 2006 | 01:28 AM
Zonda's Avatar
Zonda
I just bought those same headlights and they never seemed to work the low beams would screw up. Did you install those your self ?
Old Jan 24, 2006 | 09:19 PM
FL_ThunderRoad
I actually took the time to install these and used a circuit tester.
Here is what my truck looks like with them on.
