carrier bearing
Old Jan 23, 2006 | 01:22 AM
RattlingRam01's Avatar
RattlingRam01
Default carrier bearing
Howdy, I need to replace the carrier bearing in my 01 Qd-cab as the driveshaft has been shuddering all week. As soothing as the vibrations are on my back, I forked out the 162 bucks for the bearing , and crawled under the truck to take a look at the driveshaft. Problem is, I'm not sure how the support and bearing comes off the driveshaft. I'm assuming I need to mark and remove the middle U-Joint, and unbolt the support, but how then does it slide off the shaft? is there something magic under that dust boot between the two? Anybody?
